1⁄35F14A Tomcat - PART FOUR
At the time I started this model, no after-market company made decals for this aircraft. After visiting NAS Fallon in person and creating my own decals for the model, I found the notice on the TwoBobs Decals web site stating that they were going to produce decals for this exact aircraft. I got excited and sent TwoBobs an e-mail asking if they would be interested in my research on the aircraft. They were very interested. To make a long story short, this model is built using the new TwoBobs decals which I received from them as compensation for all my help on the decals.
I do not want to sound like a TwoBobs commercial, here, but the decal sheet is
very complete. I made sure of that while I was helping them. It provides
markings for the aircraft as it was seen in May of 1999. There were changes in
the camouflage by April of 2000 and still more by September of 2000 that
interupted the original design of the camouflage. I have noted the variations in
my camouflage diagrams above.
A few issues with the decals exist, but are not that noticable on the completed
model.
- The "NSAWC" and small "20" on the tails are in black. They should be gray to
match the lightning bolts. Likewise, the square and the writing for the fire
extinguisher entry on the engine nacelle side are also black, but should be
gray. After talking to TwoBobs, I learned these were image glitches with the
software they used to create the decal images. These markings were gray in the
original images, but when they translated the images to send to them to the
printer, the software revised the colors of these images. Fortunately, none of
the rest of the markings on the sheet were effected.
- The small "20" on the tails should be at least 50% larger and bolder.
- The "20" on the nose should be about 15% larger and bolder.
- The "Danger Arresting Hook" markings on the sides of the beaver tail should be
at least 100% to 150% larger. I actually printed replacements for these markings
to use on my model using clear decal film and my ALPS printer.
- The fire extinguisher writing should be about 50% smaller.
- The lightning bolts are not sloped enough on the decal sheet. When the decals
are applied, following the natural slope of the tails, the angle of the top of
the lightning bolt is at the wrong slant. I fixed this by trimming the top of
the decals on the model before the decals dried.
- Also, the Topgun badges end up
not being oriented properly. This is best seen when applying the yellow
cross-hair decals. The vertical orientation of the cross-hairs hits the MiG and
surrounding writing differently on the left side from the right side.
- All the provided slime lights are identical in size. While this is true of the
real lights on the real Tomcat, the Hasegawa scribing of the tail top lights is
different in size to the scribing on nose sides. The decals are a bit taller and
a lot smaller in width than the scribing on the tail tops. The slime lights do
match perfectly to the scribed lights on the sides of the nose, though. I did
some judicious slicing to shorten the height of the lights for the tail tops.
Then added some extra width to the lights by using some of the extra slime
lights on the sheet.
- Lastly, the turbine warning stripe should be about 25% wider and shortened in length by about a quarter of an inch. I applied a second stripe along side of the first stripe to increase its width on the model. Then, I trimmed the stripes to the correct length before the decals dried.
I only noticed these things because I saw the aircraft in person and did a lot
of research to create my own decals for the model (prior to learning that
TwoBobs was doing it). On the completed model, none of these issues is of any
great consequence. I applied the decals using Solv-a-set and had no troubles of
any sort.
