1⁄48Focke-Wulf Fw 190D - Eduard Review-Build #2
5
Painting & Decals
I chose to depict Oblt. Hans Dortenmann's aircraft in its final scheme. I used LifeColor acrylics and took a few liberties with the camouflage and markings because there don't seem to be photos of the overall scheme to prove matters one way or another. Dortenmann's aircraft was the first operational Dora, so I painted the undersides in standard RLM 76 and, as it was built by Focke-Wulf and (presumably) left the factory finished according to regulations I misted on RLM 02 on the fuselage sides (photos of the aircraft do show quite dark sides). For a bit of variety I painted the late-style drop tank in Grau-Blau. The aircraft topsides were partly repainted at some stage, but my painters have been lazy (i.e. human!) and just left the tip of the fin in its original finish rather than paint 'round the W.Nummer (a photo of a similar aircraft shows the same thing), and I added a few other touches of the former camouflage showing, and to indicate the bulged canopy was a replacement I painted it in a slightly different green as a sign of fresh paint and/or another batch.The decals are beautiful quality, with precise registration, but I found a few annoying points. The fuselage cross on my colour scheme is odd, because you need to paint the black centre. I don't know if that's a mix-up on Eduard's part, because it's not indicated on the "Scheme F" painting diagram that I was following (it is shown for Dortenmann's alternative "Scheme B"). It's not the end of the world, but it requires careful masking and I have to admit this fiddly and rather nerve wracking (I was worried the tape would lift the decals) job was the one part of the build I found a real pain - there were so many ways it could have ended in disaster...
More worrying is that the fuselage number seems very large - bigger than in both Eduard's and Jerry Crandall's artwork, and definitely bigger than what's partially visible in the only photo I have that shows it (in its earlier "Black 1 style). The B4 fuel triangle is also too big too for Dortenmann's aircraft.
The spinner spiral decal for Dortenmann's colour scheme defeated me! Although it would go on, the resulting spiral was nowhere near as tight as either Eduard or Jerry Crandall show in their profiles, so I scrapped it. I was ready to paint a spiral when I spotted an old Microscale sheet meant for a Ju 87 in my decals stash and found it fitted just about right. The spiral seems to end "in mid-air" on all the profiles, so I've taken the cut-off point to be the panel line around the spinner.
Conclusion
Eduard's Dora 9 is a very fine kit. There are a few points to watch out for, but average modellers should have few problems. Some of its more vocal critics have made a meal out of the kit's few problem points, but Jean-Luc's model shows just how good it looks built straight out of the box. I felt it was worth doing a bit of work on the propeller, under the nose and changing the drop tank as much for the challenge as for any dramatic visual improvement - and, of course, it's always nice to know your model is a little different from the next guy's..References
Focke-Wulf 190 Dora, Volume 1 - Eagle Editions, 2007Focke-Wulf 190D Camouflage & Markings Part1 - JaPo, 2005
Close-Up #10, Fw 190D - Monogram Aviation Publications, 1990
Focke-Wulf 190D & Ta 152 - Model Art #336 - Model Art Co. Ltd., 1989
German Aircraft Cockpits 1911-1970 - Peter W. Cohasz, Schiffer, 2003
German Aircraft Interiors 1935-1945 - Monogram Aviation Publications, 1996
Here is the other great Dora
I can see some p-51D with blue nose (8th bomber command ) (I hate them ) approaching
Cheers Nick
APR 10, 2010 - 05:45 AM
Cheers Nick
Your kind words are much appreciated.
I'll have some more Luftwaffe and Regia Aeronautica stuff soon(-ish) which you might like, but you'll have to look away when I post my Spitfire and the Mustang which I have planned.
APR 11, 2010 - 12:57 AM
Beautiful build, Rowan! The build by Jean-Luc is also stunning.
This Eduard kit is a must have in the collection. I will wait until they release the Royal Class edition.
Thanks for the detailed review of this kit.
APR 19, 2010 - 12:29 AM
Many thanks Jesper
I know Jean-Luc is working on a version with corrections for a magazine-build - that should be really spectacular!
APR 19, 2010 - 04:59 AM
well I'm a bit late on this one - nothing like the arrival of the box on the bench to get you a little hot under the collar - but that is fantastic work. Thanks for the tips on the prop!
JAN 09, 2011 - 10:45 PM
Copyright ©2021 by Rowan Baylis. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2010-04-10 00:00:00. Unique Reads: 34781
