1⁄35Shinden That Never Was
The conversion is a proposed version by the manufacture
mounting the same jet engine in the ME 262. The conversion is simple and
would be good for a first try.
The jet exhaust will replace the prop so consign it to the parts box. The exhaust can be grafted on the from the rear of the Monogram Me 262 kit or built up from tubing and putty. The kit I built had the tail pipe built around a piece of brass tubing of the correct diameter with epoxy putty around the out side. I turn this part in a lath, sanding it to the correct profile. I also cut a lip to fit into the kit part # B10. Now you can assemble the wings to the fuselage and the assemble is complete.
Paint the aircraft in the kit recommended colors and markings or chose your
own. Copyright ©2002 - Text and Photos by Steve Brooks (Salt6). All Rights Reserved. |
