The mottling along the fuselage looks great. Did you do it freehand or mask it? It's the one area that i have difficulty getting look realistic.Thank you,Bob![]()
Hi Bob,
this is my first go at doing the mottling. I masked the upper fusleage and sprayed but then realised that the instructions called for a more "freehand" look so I just freehanded the bottom and then mottled the sides. It wasn't easy as I am still learning how to use my airbrush and what air pressure and paint consistancy to use. I ended up usning the lifecolour straight from the bottle without thinning and had to keep cleaning the tip of the airbrush every minute or so. I actually had a few "oopsies"- an example is on the rear right where the big patch of RLM 74 is, it started out as a mottle but ended up as one big band.
Being only my second plane I am happy with the results.
cheers
