Some WWI aircraft ( Fokker E series, Oeffag built Albatros DIII ) had engine cowlings that were "engine-turned" which gave a random "whorled" effect. Can anyone please tell me how to get this effect in 1/48 scale?
Thanks
Clive Mason ( modulla )
"engine-turned" metal
modulla
KitMaker: 72 posts
AeroScale: 71 posts
Posted: Monday, October 06, 2008 - 07:41 PM UTC
legendasboy
KitMaker: 168 posts
AeroScale: 159 posts
Posted: Tuesday, October 07, 2008 - 12:02 AM UTC
i would like to see a answer to that question 2
Posted: Tuesday, October 07, 2008 - 01:34 AM UTC
Try this on scrap plastic to get the feel. First 3-5 coats of Testors buffable aluminum. Next a "dull" edged drill bit at low speed. Walk the drill bit at low speed over the surface at a steady pace, not leaving it in one spot too long. Viola or Whallah if you will.
redcobra04
KitMaker: 235 posts
AeroScale: 44 posts
Posted: Tuesday, October 07, 2008 - 03:14 AM UTC
I agree with most of the last answer. A pencil eraser works real good used in the same way. Justb trim it down and try it on some scrap plastic first. I believe Dremel also makes a rubber bit to. Have used it to make the engine turned dash for a Trans Am model car.
legendasboy
KitMaker: 168 posts
Posted: Tuesday, October 07, 2008 - 04:13 AM UTC
ty for the help
modulla
KitMaker: 72 posts
AeroScale: 71 posts
Posted: Tuesday, October 07, 2008 - 08:32 PM UTC
Thanks, everyone
Modulla
Modulla
JimMrr
KitMaker: 1,505 posts
AeroScale: 595 posts
Posted: Wednesday, October 08, 2008 - 03:30 PM UTC
I have seen it done by spraying the cowl black...and using a thin brush paint a random squiggle pattern in silver chrome paint all over the cowl. after it has cured, overspray a light,thin coat of silver over the entire cowl,and build out the colour until satisfied..overspray with clearcote ..it looks really good when finished
Posted: Wednesday, October 08, 2008 - 05:47 PM UTC
Here is a bit of fun on the subject.
