Thanks Terri...yes ..its about 24" wingspan on her...or 60 cm..Ill have to find a home for it once its done cause I havent the room!
I have finished all the scribing and riveting on the fuselage and main wing ,all thats left is the tailplanes to do ...but Im taking a break from riveting ...
There were alot of straight panel lines to cut ,which were easy ......once you practice a bit ..
the curved ones required some brainpower....luckily I know someone with a brain...Terri suggested using a popcan for template material, so here we go..
I used paper backing from an old decal sheet and embossed the panel lines onto it with the side of a pencil, and trimmed it with scissors to make a paper template. This I checked against the nacelle.
I then stuck the paper mask/template onto a sheet of tincan which I cut from a popcan. Ill keep this stuff in my kit from now on THANKS Terri!
Out came the airbrush and I oversprayed it to create a profile of the mask...
out came scissors again and I cut out my new template.....custom and everything ..
I taped all my templates in place using masking tape, and used a pinvise with a pin in it to scribe..... for long straight cuts on the wing I used a P-cutter...
there were some acess panels on the wing also. I scribed the square onto tinsheet,then drilled in the corners to get a rounded edge ,and cut it out with my hobby knife. These home made templates work great I think.
I sanded lightly over everything and cleaned off all my work with rubbing alcohol to remove tapeglue and other unmentionables..
I had some old DYMO tape left over from the days of Yore, so I cut some and Masking taped it in place to double secure it ..then used my ponce wheel to SLOWLY run along the edge,making rivet lines. LOTSA rivets ...
I still have the aelerons to do ,and some clean up on the landing flaps, but I think I need a break from this wing so Im going to tackle the engines today...cheers..
