The were a few problems for me with this first part of the assembly, some of them my own fault. I had read on a review of the original French Airforce release that the cockpit framework was too wide, so as there is a lack of positive location points I deliberately made mine narrow - when I assembled the fuselage halves I then had to try and spread the frame to fit!. The bulkhead behind the cockpit is too wide, and I would have had a gap of about 3/16" at the top of the fuselage so it needed a fair bit of filing and trimming to get a good joint.. I have already mentioned the lack of positive location points, thankfully the instruction leaflet is fairly clear as to the locations but it is still open to a bit of trial and error fitting. The kit instrument dials were a pain in the ar... neck as they are so small, and the PE bezels are hard to fit over the top of them. One of mine lost it's print during trimming and another fell off and got lost whilst fitting the cockpit to the fuselage. I also fitted the firewall at this stage to add strength to the fuselage.
Seat with etched belts added:
Cockpit parts laid out for assembly:
Cockpit framework assembled
Rear fuselage with holes drilled (but not yet cleaned up) for rigging;
Cockpit parts painted, instrument faces still to be added:
Cockpit with a brown ink wash, fuselage halves assembled:
Next step is the fuselage joint, tailplane etc and drilling the wings before assembly for later rigging.
