as the every professional modeller, which I'm trying to be, must have more than one model on the workbench at the moment I decided to dug out of the "waste-box" these two models. Both are 1:72 scale by Revell.
I started them in 2005 but due to the arrising problems I almost junk them. The biggest problem with these kits were the canopies. Revell's moulds, after few years of producing the kits, seemed to be completely worn out because the canopies even didn't have the proper shape not mentioning any frames or details. I send them a letter of complaint and got new ones: looking even worse... So I had no motivation to finish these kits. Then I found Pavla vac canopies...and so the story of this thread begins.
Here's what I have to deal with.
The Mustang will require much more work. I have used it for testing home made masks as you see. While building I have also tried to adopt some other canopies which I found in the "spares" but with no good result - that's why the cockpit area is so massacred.
Revell decided to make only one empty shell case chute for two machine-guns...
And this is Die Schwalbe. I didn't change anything in the shape of model or canopy althouth I will also have to use Pavla vac-formed. This model requires some filling and sanding as the accuracy of the parts deteriorated on the wing-fuselage joint.
By the way: could you please help me identyfing colours of this plane as I'm not very good with the Luftwaffe...
