Progress report.
Well today was a case of two steps foreward, two steps back.
As was suggested by Terri on the AeroScale page, I spent most of my modeling time trying to use Tamiya tape to get the taped cabane struts to look right. Having tried several different techniques and finally stumbled on a method that seemed to work. I taped one end of a 6 inch long 1/8 inch wide piece of Tamiya tape sticky side up to my work table. Starting at the other end of the tape I could then wrap the tape on the strut keeping enough tension on the tape to solve the problem that the strut is not the same width over it's length. I could also by using this technique make sure the tape overlaped itself the same over the length of the strut. I painted two coats of Future to seal everything and then slapped on a quick coat of Gunze Olive Drab 1. The effect did not look too bad to the naked eye but when I took some quick photos it looked terrible. Terrible I tells ya!
Here is one of the photos to prove I will not post only pics of success.
After looking at the photos for some minuites, I threw the strut in Windex and stripped everything off.
The kind Mr. Richard Alexander of WNW fame had been looking at my build blog and sent me a nice email suggesting that anything wrapprd around the strut would be in his words "any 3D effect would be too pronounced". His suggestion is, and I quote again:
"I believe the best way to represent the fabric wrapped around some British aircraft struts is to do it with paint (any 3D effect would be too pronounced);
1 - paint struts with gloss or semi gloss PC10.
2 - do any weathering etc you plan to.
3 - carefully paint very fine lines of matt varnish to represent the frayed edges of the fabric strips.
Hope this helps."
After seeing the results of my efforts, I am inclined to believe him. Further test using paint and clear flat will be forthcoming.
Thats all for now. 'Over and Out', as it were.
mIKE :cool:
