I picked this kit up by impulse a few days back, after giving up on the Trumpeter E-3 when I found the cockpit all wrong.
I know Eduards 109s have had a fair share of critiscism but thought after reading about this it sounded a good build. Assesing things I found a few things that suprised me, besides the vast difference between Trumpie and Eduards offerings, some good and some bad on both sides.
Anyway I dived in, now anyone knows my builds from the EA forum knows I seldom take the easy route.
A trip to hannants website saw me armed with a set of quickboost exhausts, a set of resin wheels, An Aires cockpit update set.. An Eduard detail set..naughty as I believe personally this should be part of the kit, half of whats in it could be better represented in plastic with a little work.
And afterwards scribing template.
okay... hand hold mispositioned, her its filled but waiting to be rescribed. Now on this I have 2 sets of plans, one shows hand holds both sides as per the kit, the other and pics show only the left. I filled the right one. Oil filler on the eduard was miniscule, and is quite prominant I think.
Fuel filler is in the right place I think but wrong shape, however the fuselage section line is too far back, moving the cap and making it the right shape seemed an easier option.
I just love opening up vents..sorry!
Ejection ports misplaced? and I think the blisters are out of position too, but I'm taking them as is, for now at least.
I cut the underside of the nose off to work on it, this is a very poor area on the kit I thought. Trumpeter handled it better in a way but got the shape wrong. Eduard handled it well but could have put more thought into it
So I stregnthened the area generally, made up the cheek fillets in the rad intake and exit, wanted to paith the component parts seperately so chopped it as you see. I cut in the panel lines in front and under the intake, trying to reproduce the lapped over effect. Now in pics of the trop I cant see any with the extra vane in the intake so left that out., I have to make the flap for the rear still though. I happily carved out all the fastener locations to fit the eduard etched ones, only to find there isnt enough on the fret...NOT HAPPY Mr Eduard!
Though I havent shown it, I wasnt happy with the what seemed too pronounced bumps on the upper cowl and have sanded and shaved them down, I need to find better ref for the tropical filter, I dont think what Eduard show is particularly correct.
The offering by Eduard of this I think is very poor, I stole the trumpeter parts and detailed them they look much finer and a truer representation, however the droptank has a flat section with an indent, not sure if that is was or could be correct?
Finally... the rudder, I do like the eduard control surfaces, especiaplly compared to the Trumpeter ones which are FAT edged.
But the control horns were molded as a quarter circle, the etch ones are far to flat and flimsy so I scratched them oooh clever me
Now it might seem like I have a downer on this kit but its not so, just I expected after all is said and done for things to be where they should be, I love Eduards WWI offerings of late and after all the hype I maybe expected too much, Anyway its still enjoyabe to buil
Fitting sections of engine etc wher it shows through the various openings in the cowls is possible with trimming.
cheers, any comments taken good, bad scathing or advice are all welcome
Keith
