Here is an old kit by THE EAGLES TALON, INC.
LAVOCHKIN LA-7 it looks easy enough to do a little cutting and SANDING on to get myself in some sort of ability to accomplish the build for the VAC ATTACK campaign (MPM AVIA Av.135)
the resin is not bad, but I will have to make a prop blade after the carpet monster ate one that broke off in the bag
After using a pencil to outline the parts for the sanding process I cut them out
Made fuselage formers from surplus stock from the kit using a circle timplate, the first peices sanded were the fuselage and they were warped
the wing tops will not be too bad to sand but the bottom has a dihedral and will give me some trouble.
Bob
