Quoted TextTo be honest, I think there might be a problem with the wing, and also with another part I just realised. But I wont elaborate since I havent seen the real model yet and I wont make conclusons based on these few pictures. I will definitely buy it when it comes out.
I think the pictures show clearly this is the straight wing version: Look at the drawings and then the kit: The 20 mm cannons, on the kit, look almost perpendicular to the leading edge of the straight wing, which is a long, long, LONG way of being so on the swept wing...
It's just that the straight wing did have a slight trailing edge kink, and some leading edge sweep as well...
I'm actually leaning your way that there might be a problem with the wings: The inside trailing edges seem to have a little bit too much "kink" for a straight wing, but the wings don't look like swept wings at all: I think it is possible a bit of trimming will be needed at the inner trailing edge to make a more correct straight wing...
The pitot tube position varied as the pylon-mounted straight wing I posted shows: It matches the Tamiya kit...:
We will know soon enough: It is due out in Hobby Shops this very month, if one source is to be believed...
Gaston
