Thanks guys!
Kenneth, I am checking your build for tips as I do mine
Rowan, yes, they turned out quite well I think. The sidepanels are indeed the kit decals as well, I just trimmed off some bits where there was a large protrusion and the settled down great using Mr. Mark Softner!
I prefer to use kit parts whenever possible, as I don't like to add even more work trying to get some aftermarket stuff to fit. I try to reserve my enhancement time to areas that are easily seen on the finished model - aerials, gunsights, seatbelts, etc.)
Finally made some more progress on this bird, figured I better get cracking since the deadline is fast approaching!
Here is the engine (all kit parts):
With the cowl glued in place, you can see some of it:
With the fan in place, you can just barely see some of the engine if you look for it:
Wing together:
I am not crazy about the inserts in the bottom for the proper ejection ports, as one ended up a smidge high, the other a smidge low, so sanding was in order. Another couple nit-picks are that the flaps are molded for the open position only, so one needs to modify them a bit (cut off tabs, sand down lip) to get them to fit closed. One also needs to cut out an area on the bottom for the outer MG's (A6 only) - sadly the cutout is not the correct shape, but I made it work in the end
Well, here she is stuck together for a photo op, none of the major bits is glued together at this point:
Thanks for looking, comments/questions appreciated!
Doug
