And the project moves on into A.D. 2013!
Weathering (or the part of it that is intended to break up the rather monochrome finish) has now started!
Starboard wing has been through most of the process while the port one has only gotten a greyish wash yet.
As I wrote earlier, the contrast between the upper surface greens is a bit on the heavy side, the wash will even it out. The panel lines look very dark in the photos, they are a lot more restrained in reality (has a lot to do with the way I handle my photos in Lightroom, I like this look a lot but it might not be that suitable for plastic models
Lower surfaces got a wash as well. Not as carefully administered though since I always spend most of the work where it can be seen and appreciated
This is the stuff I use. I have been experimenting with all sorts of stuff for washes and filters, this is probably the best yet for my purposes!
Artist's oils work very well, the problem is that my favourite Gunze acrylic doesn't get along very well with it.
Ordinary watercolour is very safe but it tends to form puddles and it rubs off very easily when dry.
The above stuff seems to be a good combination of both: the "glaze" is probably nothing else than the stuff that the pigments swim in in ordinary paint, it can then be tinted with the colour of your choice and diluted with water to create whatever wash you like. It dries slowly and it doesn't bite into the underlying paint so it is easy to handle on the model and can be washed away by a brush dipped in water if you don't like the effect! Try it, you might like it!
Magnus
