Hi Gaston
Many thanks for posting the photo. I'm sure you'd be the first to agree that, as it's off-centre and with only one end of the measure visible, "it'd never stand up as evidence in court" - but at least it's one in the eye for anyone (myself included) who doubted its existence.
Thanks Rowan. Note that whether the spinner is 635 mm or 647 mm, that difference is about 0.25 mm in 1/48th, so it is a bit below what would be of any significance for me, even on a smaller item like the spinner. (I place the threshold for trying to correct that size of item in 1/48th at one third mm or thereabouts: Below that, you could sand or just use a thick coat of paint!)
It appears that whatever the problem is with the Tamiya kit, it is not directly related to the spinner diameter.
I'll post here the pictures that led me to believe that there is a problem with the spinner/cowl interaction (1/32 kit at the top):
I have ordered two Spitfire Mk IX overtrees from Eduard, and will get the Tamiya 1/32 kit at the same time: When I get all of this and assemble the kits, we will see better what the differences are between them, and between them and the photos of the real thing.
I'm sure other reviewers might have come up with the same idea eventually anyway, but I'll focus on what I think are the problem areas.
To me the problem with the nose is not subtle, and it is not a matter of something a thick layer of paint or even a bit of sanding could easily solve, especially considering the renowned thinness of the cowl parts...
In two weeks or thereabouts I'll post pictures and more difinitive conclusions, since only having the assembled kits in hand will do apparently...
Gaston
P.S. As for the previous Mk XII/F. XVII controversy, considering the excellent Airfix PR XIX that just came out (and about which you'll note I have no complaints), I think it pretty much amounts to a disavowal by Airfix of their own recent Griffon Spitfires, even taking into account the numerous variant differences... I'll probably compare these kits down the line as well...
