A new antenna post instead of the plastic one that I cut off early in the project. This is made from 1/0.8 mm diameter Albion Alloy aluminium tubing that I pressed flat using a pair of pliers and then sanded to a slight wedge shape. I avoided pressing the lower end so that I could mount it in a 1 mm hole drilled in the fuselage spine. Aluminium is very pliable and easy to handle.
Another use for Albion tubing, this time brass. There will be one final section inserted after painting forming a full pitot tube assembly. The hole in the leading edge to the right was just a test... OK, I admit it, I managed to drill in the wrong spot...
Neighbouring sizes fits into each other making this kind of work a breeze. Cutting is done by carefully rolling the tube below a scalpel blade and then simply snapping it. In 99% of the cases I get a perfectly square and clean cut, if there are any burrs they are easily removed using the tip of a drill.
Magnus
