I had a feeling that you had the colours mixed up but I just wanted to make sure
I could send you some camo masks for the Spitfire? just for the postage. I also have what I call, "D-Day strip helpers", they are not full D-Day stripe masks, they would be very difficult to draw accurately because of the compound curvature of the wings and, particularly, the fuselage. What they do do though is to give you the correct width of each stripe (9.53mm, 0.38")and the means to mask off each stripe. The camo masks and the D-Day stripe helpers do require that you follow the instructions carefully
Yes, the D-Day stripes were all painted on over the 5th June and anything was used from spraying them to paint brushes, rags and even brooms! So most of them were pretty rough looking. However if you replicate this on a model it just looks as if you can't paint simple stripes; unless you place the model in a diorama
