1:32 Hasegawa P-51D-5-NA
FlorinM
KitMaker: 385 posts
AeroScale: 173 posts
Posted: Tuesday, March 24, 2015 - 07:22 PM UTC
Completed on schedule and on its way to the new owner.
bdanie6
KitMaker: 615 posts
AeroScale: 459 posts
Posted: Wednesday, March 25, 2015 - 10:02 AM UTC
Well done Florin
Later
Later
Posted: Wednesday, March 25, 2015 - 12:03 PM UTC
Nicely done
FlorinM
KitMaker: 385 posts
Posted: Wednesday, March 25, 2015 - 12:25 PM UTC
Thank you!
bomber14
KitMaker: 330 posts
AeroScale: 286 posts
Posted: Monday, March 30, 2015 - 12:26 AM UTC
nice job florin. you said you put a coat of future on to seal the decals. did you spray anything over that? like a semigloss to knock the shine of the future down a little?
also you said something about the foil oxidizing. how long does it take? and does BMF oxidize too?
thanks, joe
thanks, joe
FlorinM
KitMaker: 385 posts
Posted: Monday, March 30, 2015 - 01:57 AM UTC
Just one coat of Future,that's it. You can't tell difference between the areas coated with Future and the areas that weren't because the aluminum itself is so shiny.
With regard to foil oxidizing, it is a lengthy natural process and it takes months, maybe more (depending on air temperature and humidity). It could be done quickly by using an oxidizing agent, but the reaction is risky because of the heat it gives off that can potentially melt the plastic underneath and secondly it is very hard to control in order to get the desired results.
Forgive me, but what is BMF?
bomber14
KitMaker: 330 posts
Posted: Monday, March 30, 2015 - 07:23 AM UTC
no problem- BMF is referring to bare metal foil. it comes pre glued. you probably have used it. I just wasn't sure if it would react to the oxidizing like aluminum foil but don't worry about answering that since I don't think I would wait months waiting for the foil to oxidize lol.
thanks for the quick answer and once again great work. I plan on making a replica of a restored mustang that is in a flying museum in virgina and wanted it to look like it was weathered/oxidized. guess I will start with alclad old aluminum.
thanks again- joe.
thanks again- joe.
FlorinM
KitMaker: 385 posts
Posted: Monday, March 30, 2015 - 09:48 AM UTC
To coat this model household aluminum foil and the 3 hour oil based Gold Size Mixtion Charbonnel made by Lefranc & Bourgeois was used.In all probability Bare Metal Foil is aluminum foil, so it will also oxidize in time.Good luck with your restored bird's replica!
