As I was weathering the white parts of the cowling panels, the chipping in contrast with the white cowling in my opinion became much too garish and dark, and I accidentally tapped the nose (*gasp*) against the lip of the open container of XF-56 metallic gray.
Since I initially decided I was going to respray the nose no matter what, I performed a little experiment after hearing that Tamiya acrylic thinner doesn't affect the cellulose-based lacquer sprays.
The metallic gray chipping on the nose had been drying for maybe ~10 minutes at this point. I am not sure how well this method works with acrylic that has dried overnight. I also figure it would look better with brown or black paint
Taking a soft paintbrush, I dabbed the acrylic thinner in the areas that I wanted (the cowling panel lines), and after waiting for about 15 seconds, I wiped away the thinner with a paper towel. I repeated this until I got the effect I wanted, with the paint staying in the panel lines.
No respraying necessary!
I unfortunately missed Damian's post about the wheel hub decorations; using the photos I had, I misinterpreted the points of the star to be the six holes on the hub of the wheel with the cover removed, and the white part of the star to be the raised area of the hub...but then again the covers could have been dented or ripped up and left flapping around by debris on the runway or in combat and temporarily taken off to be replaced. No biggie. I figure Mahurin would want to keep his decoration and so would have procured another set of wheel hub covers.
