wow, very cool. Which flat white did you add to the alclad? Did you apply it by brush at that point, or did you airbrush in a squiggle pattern?.
Fascinating technique.
Used Alclad II matt white (ALCE101) - works a treat 😸
Squiggly pattern was done using brush. What is interesting depending on the dilution of the aluminum + white matt mixture you can get different results. If you keep it more diluted then use it to get machined aluminum, but if you make it thicker you can with some practice and patience go for the hammered metal
Bart
