hey! thank you all for the kind comments!
Matt, you are completely right! I am not sure at all, but I could not resist to have that red showing.... call it modeller's licence!
Patick! thank you again! maybe because I built a lot of wwii planes during my young age, I find them quite boring today:too sleek too stremlied, all closed up under the fusolage.... but this one is fantastic! so much to do and to show, real fun!
being my first wwii subject afer so many years, i am not a master at all, so don't take my world too seriuosly
Anyway, for the underside of the wing, I used Tamiya flat white as a base coat. Then I used Tamiya smoke to highlight the panel lines (if you happen to overdo it, just overcoat again in white to smooth it off). After a coat of Clear, I washed the panel lines with a mix of raw umber and black oils.
The decals are thick in my opinion and even with microsol, they just hide the rivets, so i drilled them out with a pin wise: fortunately the rivets can be seen notwistanding the decals and the scale is so big that you can easily find a drill of the appropriate size! then the wash and a coat of Tamiya clear flat to finish it off.
I hope it helps!
ciao
edo
