OFFICIAL: Sukhoi Campaign
#460
California, United States
KitMaker: 1,156 posts
AeroScale: 92 posts
Posted: Tuesday, March 19, 2019 - 11:02 AM UTC
I have been beavering away on this old Sukhoi Su-9 and its just about time to close the fuselage. The seat has been a lot of fun. I got an Eduard "fabric" seatbelt set for a MiG-21, the closest I could find for this model. They are really die-cut printed paper with PE parts. The builder is supposed to be able to thread the paper through the PE buckles to make a realistic looking set. Haw! I can barely SEE the damn things and after spending an evening trying gave up and glued the PE on top. It looks almost as good and considering all the other issues with the cockpit I will not loose any sleep over the belts. This picture shows were the project is now.
The front wheel well is partially assembled and has been painted. It will need a wash or three and detail painting before final assembly. The nose gear gets trapped inside the box and then that gets trapped inside the fuselage. I can't see any easy way to mask this off. Any ideas?
Vintage Paul
I'd happily live in the past but for air conditioning, the internet, mobile phones, modern medicine & dentistry and, and, and . . .
#460
AeroScale: 92 posts
Posted: Friday, March 22, 2019 - 06:26 AM UTC
More progress on the Su-9 to report. I screwed up the nose wheel well. It got two nice coats of light grey enamal and I let it sit 24 hours. The next evening it got a wash of flat black which krinkled the grey. No worries, I'll wash it all off with lacquer thinner. I forgot that some plastics melt in this stuff and the part got slick, slipped out of the tweezers & into the jar. After fishing around for some time I had to pour off the solvent and only then could recover the partially melted part. I let it sit overnight and then reworked it with a sanding stick & an Exacto. It will be OK to hold the landing gear but will never be worth looking at. Like they say in the Navy, I welded it together & painted it grey, a dark shade to try to hide the damage.
Last night the fuselage halves went together and I painted the seams with liquid cement. I'll try sanding those seams this evening and see how good my fit was.
Here are some photos of where things are now with the fore & after deck sections trial fitted:
These large pictures sure show up the flaws in my detail painting . . .
Vintage Paul
#442
Malacca, Malaysia
KitMaker: 363 posts
AeroScale: 335 posts
Posted: Saturday, March 23, 2019 - 01:01 AM UTC
Gee Paul,
Me thinks you're being to hard on yourself! Looks pretty good from here!
John
#460
AeroScale: 92 posts
Posted: Monday, March 25, 2019 - 06:13 AM UTC
Thanks John, it looks OK with my glasses too. Blown up on the screen can get scary . . .
Vintage Paul
#460
AeroScale: 92 posts
Posted: Monday, March 25, 2019 - 06:22 AM UTC
A bit more work to show:
Looking at the days left to complete makes it obvious that some things will have to be given up to get this project in before the gong. First, I'll leave the stores off. I often like to leave the plane bare anyway to better reveal the shape. I may have to forego the primer coat also and just go directly to the MRP Duraluminum. We'll have to see about that . . .
I thought is might be fun to show a picture found online of an Su-7 cockpit which shows the color that the Su-9 was probably also painted. It looks pretty close to the MRP Grey-Blue paint.
Vintage Paul
#460
AeroScale: 92 posts
Posted: Tuesday, March 26, 2019 - 05:30 AM UTC
I ran into some trouble with the seams last night. I had hopes that by careful fitting and the use of liquid cement the seams would not be an issue. Last night I was using the new to me Micro Mesh pads and polishing down the surfaces the seams appeared on the fuselage joints. The seams on the wings & tail were pretty good but the ones on the fuselage were still there in places.
I went back to square one and had at them again with a sanding stick hoping to find the bottom of the trough. In the end I was thoroughly disgusted with my approach. I ran new liquid glue and will see what we have next work session. I may end up having to try another new to me technique, using CA glue as filler.
All my panel lines are gone on the top & bottom but at least it will be smooth!
Vintage Paul
Jihocesky Kraj, Czech Republic
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Tuesday, March 26, 2019 - 06:00 AM UTC
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Wednesday, March 27, 2019 - 05:34 AM UTC
Todays post No.1-Engines, aircraftbody and preparing the base
exhaust and engines:
Final exhaust
engines:
Final:
Inside view:
Aircraft:
Base coat:
Scrapping, base weathering:
Base:
Grass implantation:
Preparing for snow:
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Wednesday, March 27, 2019 - 05:40 AM UTC
Todays Post No.2:
spraying the Marking and art. Classical stencils are used only for labels:
Spraying the Bear:
Final:
Spraying the Flag and letters just after spraying:
Cat and stripes:
Stars and sidewalks:
#460
AeroScale: 92 posts
Posted: Wednesday, March 27, 2019 - 06:22 AM UTC
Martin - this is all looking very nice! Your stencils are amazing. Are they a commercial product? Do they stick to the surface? I look forward to seeing more of this project.
Vintage Paul
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Wednesday, March 27, 2019 - 06:42 AM UTC
Hi Paul, thank you.
The final photos are in Gallery now. About the stencils: This specific stencils will released soon. You will find, not only, them on
www.miryoku.cz. Write me PM, I will send you more information, when you are interested in. ;-) We were looking for material more than 1 year. Is semitransparent, glue is strong not much but strong to prevent under spraying. This one copying survace excelent.
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Thursday, March 28, 2019 - 08:29 AM UTC
Spain / España
KitMaker: 103 posts
AeroScale: 102 posts
Posted: Thursday, March 28, 2019 - 11:16 PM UTC
Martin, that is amazing! Everything looks great, I love particularly the subtle weathering and the snowy airfield. Thanks for sharing.
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Thursday, March 28, 2019 - 11:23 PM UTC
Thanks Carlos, my pleasure you like it.
#442
Malacca, Malaysia
KitMaker: 363 posts
Posted: Friday, March 29, 2019 - 12:56 AM UTC
Martin,
Nice job! Love the weathering effect!
Paul,
Yours is coming together, and looks great!
#460
AeroScale: 92 posts
Posted: Friday, March 29, 2019 - 12:26 PM UTC
I'm getting close and if all goes well I stand a chance of completing before the deadline. Tonight I'll install the canopy & do some clean up of glued joints from last night. Then it will be masking, something I'm always nervous about. With luck the aluminum MRP finish will go on Saturday and the decals & clear coat Sunday. I'll still need to do final assembly so I hope the clear dries quickly.
Here are some pics of the finished cockpit, the first one without the shroud over the do-dads in front of the instrument panel:
These two sho the Fishpot speared and ready to tonights work:
I'm crossing my fingers for a bit of modeling luck . . .
Vintage Paul
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Friday, March 29, 2019 - 01:23 PM UTC
Well done Paul and good luck
Im looking forward to finished Su.
Vietnam
KitMaker: 416 posts
AeroScale: 89 posts
Posted: Sunday, March 31, 2019 - 02:20 AM UTC
Hi everyone,
Martin Benes (Gartik61): I feel a cold wind flowing in my eyes.
I had done my Su-33UB in 1/72 scale.
Thanks all for this great air campaign.
Regards,
K.
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Sunday, March 31, 2019 - 03:37 AM UTC
Thanks "K"
. Yours is imazing too. Clean and precize. But, realy has closed wing with AM? ;-)
Spain / España
KitMaker: 103 posts
Posted: Sunday, March 31, 2019 - 09:13 PM UTC
K., that is a great looking model. Amazing painting and weathering. Congratulations.
Vietnam
KitMaker: 416 posts
AeroScale: 89 posts
Posted: Monday, April 01, 2019 - 02:50 AM UTC
Thanks "K"
A Su-33UB and a Su-33 on the Russian aircraft carrier.
Thank so much, Martin and Carlos for your kind words.
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Monday, April 01, 2019 - 03:20 AM UTC
I forgot, Russians :-D 😉😀🤐 Superb build.
#460
AeroScale: 92 posts
Posted: Monday, April 01, 2019 - 04:08 AM UTC
I didn't make it. Modeling luck was not with me and this Fishpot will not be finished today.
Saturday I shot the model with the MRP Duraluminum paint through the airbrush. The brush worked well & the paint applied well but the results were not good. In areas where I had worked the seams with CA glue and sanded & polished them the finish looks good. Everywhere else was mixed. I had not expected the raw unpolished plastic to be the issue. Here is what it looked like:
Sunday I shot it with Tamiya AL paint out of a rattle can. It was a bit better but still no joy:
Today I will shoot the model a third time with Krylon metallic silver. Even though I have missed the deadline, I'll finish this Sukhoi. It has been an education and that has been worth something.
Vintage Paul
KitMaker: 12 posts
AeroScale: 10 posts
Posted: Monday, April 01, 2019 - 07:44 AM UTC
Hi Paul, looks like a surface defect. Did you polish surfacer before silver paint? You can use Tamiya polishing cloths.
#460
AeroScale: 92 posts
Posted: Monday, April 01, 2019 - 09:39 AM UTC
Thanks Martin for the tip about the Tamiya polishing cloths. I have not heard of them before but will see if I can order some. I did not polish the whole model, only areas where I had worked. Those came out pretty nice.
I have been building armor since I came back to modeling & the techniques I had learned building models like a 1943 T-34 do not all work on a 1960 Sukhoi . . .
I shot a third coat of paint this morning out of a Krylon rattle can. This covered much better and looks reasonably good. Decals Tuesday then a clear coat & washes. I'll finish it and it will be a step toward the next natural metal project. I have a kit of the Firebar that looks like fun down the road.
Vintage Paul
