Tinted Canopy's !!!!!
Good idea but I've always had a hard time myself with a good finish.
In this experiment, I used two canopy's and two different processes to achieve a 'LOOK'.
My colors of choice are these 3 Alclad Transparent: Yellow, Smoke, Clear Medium and Tamiya Lacquer Thinner.
I can't give an exact recipe here because it's a personal preference (eye) and some continual mixing of transparents... But for me, I continually mixed ratio's with each other color to get an acceptable 'Tint'. Then when that was done, I cut the final color with a 60% thinner to 40% color ratio to airbrush on.
Here, Left canopy has been sprayed on the 'inside' with nice wet strokes across long ways. (est. 20psi and about 4" off surface)
On the Right, same color with not as much thinning and applying the tint on the 'outside' of canopy.
In my eye, the left canopy process is my winner!!
This process was easier, coats were applied long ways and in the end, because the exterior surface of the canopy was first polished with 'novus scratch remover', it gives off a smooth sheen finish in the end.
I'll be using this canopy for my build and this process with future tinting...
Completion date?...................... Soon!
