Hi All!
Time for an update. The Medallion Models resin set is really a nice drop fit, for this kit. Not a surprise, as it was made for this kit!
Following the instructions, I diverted to the front-end, and installed the intakes first! This alone adds so much to the model.
I then proceeded to the cockpit, and added it, again drop fit!
Next, I did the instrument panel, raised, but using a cream colored prisma pencil, it looks great!
I then added the wings!
So, has this happened to anyone out there? I have found as I've gotten a bit older, that my skin, especially my hands have gotten dry. Try all sorts of moisturizer, to no avail, needless to say, upon removing the tape from the wings, the bird decided to try out it's wings!!
Things didn't go too well. Two places to land, grass or tile. Of course, tile. All in all, the damage wasn't too bad. A chip out of the rudder, and the instrument panel became dislodged.
The latter was the biggest hurdle to overcome. I fished the IP out, and started to figure out how to get it back to where it wanted to be.
Taking some sprue and cutting it, and using white glue to attach it to the IP, I had a start. Following some heat to melt, and then fashion a handle that would allow for the IP to get to where it needed to be, I was able to get it there! Note, this took about 6 times to get it right. in the end, it was close enough.
It's close enough for this go around. This build is a pre-cursor to a really cool AVG build. Then again, life might intervene. So, at least this one will get done!
