Prop was hand painted using Vallejo "Ice Yellow" over a base of reddish brown MRP, mixed from dark earth, mid stone and a drop of yellow. Touch-up was done using Vallejo "mahogany" and I also used a wash of this paint to dampen the contrasts a bit. A final coat of brush painted Vallejo semi-matte finished the prop.
Landing gear struts are attached using a nifty jig that is included with the kit, after the glue has set the jig will be removed before I paint it and attach it to the fuselage. You can also see the custom wheel axles I did since the etched wheels were impossible to fit over the plastic axle stubs.
Magnus
