The horror of it all begins to sink in! :-)
Hi there
I've been tinkering with the Halifax - and nothing I've found so far is very good...
This is one of those kits where every single part needs cleaning-up, modifying or simply replacing - depending on the time-scale/accuracy you're working to. In a probably hopeless effort to get this done by Christmas, I'm using as many kit parts as will fit - yes its that bad...
After a
massive sanding/thinning session, there was nothing left for it but to start tacking the inerior components in place. There was no point pre-painting, because everything would need more work. The interior structure on the sidewalls isn't particularly accurate compared with refs - but I used it both out of sheer "bloody-mindedness" and to illustrate any problems.
The first sign that all was not well was when I realised that, OOB, the instrument panel was hanging in the middle of nowhere and positioned halfway across a window. One look at the preserved Halifax at Hendon shows the correct position, relative to the window:
Getting the kit part into the right postion would mean moving it back and scrapping the kit cockpit floor, because the mount is in the wrong place:
If I thought the fuselage was fun, when I checked the wings, the problems really started! I was by now prepared for trouble, so I cut a circular template for the cowlings and looked at one wing... and thought "That's really not bad! Here's a chance for some quick progress to distract me from the cockpit!".
Then I checked the other wing... and it was completely different! The thing to say now is that the Halifax had a dead-straight centre section - no dihedral, no taper - and anything else rings alarm bells...
So what fun to find this using the same template:
It's not a case of over-sanding (my first thought too) - the sprue attachments are still untouched, so the wings are simply different!
Loving it? You bet!
