"Tailhooks on USAF aircraft do NOT indicate a carrier-landing capability!
The purpose of these tailhooks is to help stop the aircraft in the event of brake failure, or some similar accident leading to a runway overrun. Just past the end of many military runways, you'll find an arrester cable strung across the field. The cable (unlike those on aircraft carriers) isn't attached to anything firm; instead, each end is linked to a long chain, which just drags on the ground. The idea is to slow the aircraft down in a reasonable distance; the tailhooks on Air Force fighters are smaller and weaker than the superficially similar hooks on Navy planes.
The inevitable next question, "Does this mean Air Force planes could land on a carrier in an emergency?", has been discussed at great length. It has been conclusively established that, no, an Air Force fighter could never land on a carrier because, first, its landing gear is likely to break in the much heavier touchdown required for carrier landings; second, even if it could get on the deck in one piece, the weaker Air Force tailhook would break when it caught the Navy arrester cable; and third, even if the aircraft was physically capable of it, Air Force pilots aren't trained in the highly specialised and difficult art of carrier landings.
It has been pointed out that, if the USAF thought there was even the slightest chance of ever being able to save one of its planes by landing it on a carrier, it would have been tested on the mock carrier deck at Patuxent River; the fact that this has never been tried is pretty solid evidence that the Air Force engineers (who would presumably know) are certain it can't be done."
