I've read about this method for paint chipping and I've seen models done using it. It's a bit to random and not very realistic, for the effect I'm after. The paint would come away, mainly starting around panel junctions and particularly removeable panels. The Maskol/White glue method leaves rounded edges, but that wouldn't be the case with the paint flaking on Japanese aircraft. I'm toying with the pull off with tape method, but this to can be a bit to random and unpredictable. Mainly because it's done by laying the tape on and pulling it off and hoping for the best. The main problem with using silver pencil, or any medium used on top of the finished scheme is that it looks like that (on top) which is not correct. My thinking at the moment is: By using something like Alclad (which will take paint) first, then add the colour coats, then remove colour coats from areas you want. Problem is how? Sanding works but the edges are to graded, tape may not pull the paint off. This is what I intend to try and in about five years, when I get around to doing it, I'll report back LOL
But thanks for the suggestion penpen, there may be some trials to conduct in that direction aswell. Maybe I'll need to get to the Grand Master stage before I Maskol (master) it. (about another 20 years):-)
Mal
