Hello everyone,
I'm glad to see all the research on the Mirage and Daggers, it really clears up much about them. He is my latest reviews for you all.
Review Westland
Sea King
This is the 1/72 Fujimi kit. The parts are packaged in four plastic bags. It’s molded in grey and clear plastic and composes 112 parts but 32 of them are not used according to the directions. On exam the parts have no flash, and are very detailed. The clear parts are thin and reasonable clarity.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090124.jpg)
The directions are printed clearly in seven steps and show parts placement in detail but do not cover any of the 32 parts already mentioned. It appears these parts are for making the anti-submarine variant which was the Sea Kings primary mission for “Operation Corporate”. However, with the loss of 3 of 4 CH-47 Chinooks on the Atlantic Conveyor and the lack of Argentine Submarine activity, many Sea Kings became transport helicopters for movement of supplies and equipment.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090130.jpg)
The fuselage detail is crisp with a mix of raised and recessed panel lines and lots of rivets which look reasonable and enhance the kits appearance. The interior lacks sidewall detail and has several pre-marked areas (Dutch version) were additional windows can be installed after removing plastic with a hobby knife or other tool. The large cargo door and several windows will show some of the interior and someone may want to simulate some form of structural detail to be viewed. The air intakes are molded separate from the fuselage and are very shallow in depth and engine exhausts are shallow and blanked over. They should be drilled out and some tubing used to increase the depth of view.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090126.jpg)
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090128.jpg)
Cockpit detail is basic and no crew figures are provided. The decals are well printed and have some colorful markings, but are not applicable to “Falklands War” aircraft. There are aftermarket decals available for both Royal Navy and Argentine Navy versions.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090132.jpg)
The rotor head is nicely detailed and appears very fragile. The rotor blades are okay but do not have the droop present on aircraft at rest. From the directions it appears that maybe the rotors could be attached for shipboard storage, but the directions do not indicate such. The tail rotor is nice and well protected by its sprue, but use extreme care in removing it as the part is very thin. Landing gear detail is okay but appears small for the size of the model. Use care in handling the completed aircraft.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090129.jpg)
Overall this appears to be a great model. I did not test fit the parts but considering the overall quality and packaging of the parts I would expect this to be a straight forward build resulting in a good looking helicopter when finished. The extra parts for anti-sub mission means with a little study and thought any version could be built and since both sides used Sea Kings, aircraft color and after market decal options are available. I purchased the kit from
www.luckymodel.com on sale for $7.00 and I think it was money well spent.
Review
CH-47 Chinook
This is the 1/72 Matchbox kit. On opening the box I saw a weird sight (to me anyway) of three large, one small plastic sprues with lots of parts. Each sprue is molded in a different color! There is Green, Black, Grey and Clear colors. The kit has approx. 120 parts and the plastic appears shiny and smooth (bath in dish detergent is probably in order here). The clear parts are thick and blurry.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090134.jpg)
The instructions are carried out in 25 steps and the sheet is crowed with all the things to be done. The directions are printed in Chinese and explain building three Royal Air Force versions or US Army aircraft. One great item is the kit decals, present is markings for “Bravo November” (BN) the lone surviving British Chinook in the Falklands (the other 3 were destroyed when Atlantic Conveyor was attacked and sunk). The decal quality is okay and should be usable. The directions cover the camouflage detail for the aircraft on one side only. The box art is more useful and unless you can read Chinese the paint guide is no help.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090135.jpg)
The fuselage detail is minimal and consists of raised and recessed panel lines. Interior sidewall detail was attempted by having raised lines as well but they are sparse.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090136.jpg)
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090137.jpg)
There is a separate part for the floor boards and it is reasonably detailed. Then after the fuselage halves and floor board are glued together a third part, the bottom exterior of the helicopter is glue in place (I suspect there will be a major seem line to clean up). The cargo ramp has the option to be molded open or closed so depending on what you choose, interior detailing may be in order.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090139.jpg)
The cockpit actually has separate control sticks and seats. No crew is provided and the console detail is provided by using a decal from the sheet. However, the blurry clear parts will probably limit the detail that could be seen. The front cabin glass on my example has scratch marks, blemishes and two sinkholes in it. I do think with some fine grit wet sandpaper and a dip in “Future“, should improve the appearance.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090141.jpg)
Rotor detail is okay but all the rotor parts are molded in that black plastic (The same plastic Monogram uses) that the glue just does not seem to fuse very well. Use care as recall this type of plastic is very brittle as well.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090138.jpg)
The engine detail is okay but the intake screen is terrible and it would really improve the models appearance if actual screen (model railroad screen would work) was placed over the intakes verses the kit provided solid molded parts. Landing gear and wheels will look okay after assembly and painting. Again the plastic seems brittle to me.
![](../../i41.photobucket.com/albums/e263/bfcf623/P1090140.jpg)
This kit appears complex to me and will probably need extra effort to produce an acceptable level of detail. The decals are a nice surprise as I had no idea “BN” was included. Another plus is both sides used Chinooks on the Falklands and I think Model Decal or Hi Decal has markings for an Argentine version. Argentina used at least two Chinooks on the islands, one was destroyed on the ground by air attack, the second was captured by ground forces and a third was disabled torevent its use. BN survived the conflict. The kit is not expensive and I got this on Ebay for $6.00 US (the decals are worth that) and it isi still available in hobby shops as well . Even with the kit’s flaws I’m content with it.
Sincerely,
Brian
