Hi again
Well, back underway as promised.
The first job was a real pain... somehow or other, the kit's rudder has decided to go walkabout! So, I've bitten the bullet and made a new one. The basis was cut from a battered old Tamiya '190A and thinned down massively (Eduard's matches the thickness in plans much better). I then traced the rib pattern from the plans in Jerry Crandall's book and skinned the replacement:
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Rudder.jpg)
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Rudder_1.jpg)
I'll give the new rudder a good coat of gloss paint, flooded on a bit, to both soften the "stuck on" look of the ribs and highlight the inevitable faults where more work's needed.
Next it was time to add a few items that Eduard have missed in the kit.
The instruments coaming should have a padded lip, so I masked it off and built one up from "supafiller". It dries really quickly, so I was able to sand it down and paint later on:
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Coaming.jpg)
On the tip of the spinner there's a raised circular disk evident in photos:
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Spinner_1.jpg)
And, above the starbord exhausts there should be a small shield to prevent exhaust gases going into the intake above. It doesn't show well in the photo, but this is actually slightly curled downwards:
And finally the little strips rivetted to the wingroots. Eduard will probably include both these and the exhaust shield in a future etched set:
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Assembly_2.jpg)
As you can see, I've got the guns in and the cowling on. The supercharger is attached, although I'm not altogether sure the shape is correct.
While that lot dried, I got on with scribing in the fuselage seams. On the real aircraft the skin was overlapped slightly, resulting in the panel line being offset from the centre. According to the Jerry Crandall book's plans this offset was reversed on on the fuselage insert (perhaps for strength?):
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Panels_1.jpg)
So, time for things to go off for painting (there's one other pain - the windscreen in my kit is cracked (perhaps damaged in transit). Luckily, it should be largely hidden by the open gun cowl...) :
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Pre-Paint.jpg)
and to start a crazy scheme... a new drop tank to match the cylindrical type that is often in photos of Doras at the end of the war. The old ballpoint pen body is just about correct in diameter, so I'll see what I can come up with...
![](https://gallery.kitmaker.net/data/25407/Ed_Dora_Drop-Tank_1.jpg)
That's it for now.
