I have a question about applying lozenge to the lifting surfaces of aircraft (big flat bits of planes). How do you trim the decals on the edges of the big flat bits? I have tried it before but found that the decals tore rather than cut cleanly, even with a new blade in my knife.
I am about to apply lozenge to my WNW LVG C.VI and don't want a repeat of the torn decals I have produced before.
Thanks in advance.
Lozenge Application
![](https://gallery.kitmaker.net/data/19815/thumbs/images7.jpg)
warreni
![_VISITCOMMUNITY](../../images/flags/au.gif)
KitMaker: 5,926 posts
AeroScale: 2,201 posts
![Field Marshal](../../modules/SquawkBox/images/levels/10_11.gif)
Posted: Sunday, August 15, 2010 - 10:17 AM UTC
![_VISITCOMMUNITY](../../images/flags/us.gif)
![General of the Army](../../modules/SquawkBox/images/levels/rank.generalarmy.gif)
Posted: Sunday, August 15, 2010 - 07:30 PM UTC
Flex file. See here.
warreni
Posted: Sunday, August 15, 2010 - 08:53 PM UTC
OK Stephen. Thanks for that. I just ordered a set.. I will ask how when they arrive. WIll give lozenge ages to dry thoroughly..
![](../../modules/SquawkBox/images/smilies/smile.gif)
![](../../images/avatar/213.png)
![_VISITCOMMUNITY](../../images/flags/ca.gif)
![](../../modules/SquawkBox/images/levels/blank.gif)
Posted: Monday, August 16, 2010 - 03:53 AM UTC
Hi Warren !
For trimming off the the excess I use a new 11 blade and use a down ward montion to cut off the over hang
Start with the base of the balde and work towards to the tip in one montion .
hope this helps you
hope this helps you
Posted: Monday, August 16, 2010 - 07:03 AM UTC
OK Stephen. Thanks for that. I just ordered a set.. I will ask how when they arrive. WIll give lozenge ages to dry thoroughly..![]()
As long as all areas have dried decal on them the loose edges can be burnished with a thumb nail. then it just flakesoff. Otherwise Any decal that accidently wraps around the edges cane easily be rmoved with the flexfile. No flat edges to be concerned about. The flex file follows the contours of the surface its applied to. I have been using one for about twenty five years.
warreni
Posted: Monday, August 16, 2010 - 10:05 AM UTC
Thanks Terri and Stephen. I sprayed the wings etc with paint then gave it a coat of Future to make sure it is very glossy for the decals. Will post results whenever I get around to applying the decals. The Queen Mary 2 is keeping me more occupied than I thought it would.. ![](../../modules/SquawkBox/images/smilies/smile.gif)
