Hermon, Jesper, and everyone else, thanks for the kind words:
Well the holidays are over so back to the practice. I took Brinker's advice and tried the drywall sanding mesh and it worked very well,less than a 1/4 of the time it took to use wet sandpaper and water.
The Drywall Screen (sanding material)
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/025-11.jpg)
upper and lower wing after sanding.
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/002-55.jpg)
Wing upper glued together.
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/003-50.jpg)
Wing lower glued together. The landing gear will not be cut out until after attched to the fuselage.
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/006-34.jpg)
This is the hardest and most delicate part of the model for me, attaching the wing to the fuselage with the correct dihedral .
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/016-15.jpg)
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/018-16.jpg)
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/020-10.jpg)
![Photobucket](../../i297.photobucket.com/albums/mm230/bigrip74/023-12.jpg)
after attachment of the wing to the fuselage and I have made sure of the correct placement, dihedral I will cut out the landing gear area then place blocks that will accept the landing gear. That is for another day see ya later.
Bob
