KotS GB 2011 Junkers J.I JackFlash
_VISITCOMMUNITY
Posted: Monday, March 28, 2011 - 03:44 AM UTC
Good news! the fit is almost perfect with this attempt.
The Air Master set for the Parabellum 14 & 14/17 guns are shown add to the basic WNW kit items.
_VISITCOMMUNITY
Posted: Monday, March 28, 2011 - 02:55 PM UTC
Looking sweet Stephen ! are you going to reproduce the glass in the scope on the 14/17 ?
_VISITCOMMUNITY
Posted: Monday, March 28, 2011 - 03:36 PM UTC
Greetings Terri,
Yes, I intend on further detailing and even a bit of gunmetal dry brushing.
Kornbeef
_VISITCOMMUNITY
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Monday, March 28, 2011 - 08:15 PM UTC
They look just great Stephen obviously still WIP but those barrels just give them that extra zap.
On the Roland I tried washing the blued areas witth Blue ink from Citadel, I got a reasonable result, one I'm going to experiment further with.
Looking forwards to seeing you do the mod on this one.
Keith
_VISITCOMMUNITY
Posted: Tuesday, March 29, 2011 - 03:17 PM UTC
The lets move on! My next move is to build a mock up of the cockpit interior and save the kit part til I am sure of cuts I need to make. Always keep scrap sheet plastic! It comes in handy for these things.
OEFFAG_153
_VISITCOMMUNITY
Västra Götaland, Sweden
Posted: Wednesday, March 30, 2011 - 02:42 AM UTC
Beautiful work on the MGs Stephen – and a very interesting build thread!
dmopath
_VISITCOMMUNITY
Kentucky, United States
KitMaker: 175 posts
AeroScale: 174 posts
Posted: Wednesday, March 30, 2011 - 07:03 AM UTC
A magnificent beginning, sir...
I noticed that my lower wing does cause some minuscule splitting of the seams when dry-fitted, along with major excavation of the fuselage mount to get the center portion of the wing to seat properly. No problems with the upper wing. I guess it depends on the mold.
I will continue to follow your build closely.
RAGIII
_VISITCOMMUNITY
North Carolina, United States
KitMaker: 604 posts
AeroScale: 600 posts
Posted: Thursday, March 31, 2011 - 02:55 AM UTC
Stephen,
Glad to see you had no wing fit issues this time! The MGs look fantastic!
RAGIII
_VISITCOMMUNITY
Posted: Monday, April 04, 2011 - 04:48 PM UTC
Images here are from the WNW site and were taken by Giorgio Dorat. They show the rear cockpit of the Junkers J.I in Milan. . .The divider wall between the front and rear cockpit has been removed to accomidate the twin parabellum installation. . . "
Some more WNW images to ponder.
_VISITCOMMUNITY
Posted: Monday, April 04, 2011 - 04:54 PM UTC
As you can see some attempt has been made to repaint the basic colours on the outside.
But significant colour notations for the interior need to be observed.
They also seem to have repaired the instrument panel in the pilot's cockpit. Now when you see the images from the WNW instruction booklet you see the original state of deterioration and the extent of how differently the paint was applied to certain areas.
Note the white areas near the rear cockpit flooring and on the twin parabellum supprt frames are white (well worn but white).
_VISITCOMMUNITY
Posted: Monday, April 04, 2011 - 05:21 PM UTC
The two images shown here are at the bottom of the instruction page 18 tend to show Junkers J.I 816/17 before restoration began.
_VISITCOMMUNITY
Posted: Thursday, April 07, 2011 - 02:06 AM UTC
Ok here is some progress.
It is not yet glued in place here so I can push it in further.
Here I am checking the angle of the gun with the hole.
_VISITCOMMUNITY
Posted: Thursday, April 07, 2011 - 02:19 AM UTC
Here the clearance holes for the bullet path are plotted upper surface lower wing.
Here the clearance holes for the bullet path are plotted under surface lower wing.
These next images show the basic colours of the interior of J.I 816/17 and the modified instrument panel. The PE Bosch starter magneto is from a left over Part of Paland brass set . The kit item was removed. The current restoration on the original shows this starter mag has been moved to the new location.
There will be some white portions added to the rear cockpit per the original airframe. More to come.
_VISITCOMMUNITY
Posted: Monday, April 18, 2011 - 08:12 PM UTC
I have had to rethink my appraisal of the Parabellums being used in this Junkers J.I. Several things have changed my thinking.
1. WNW Richard Alexander's e-mails
2. German munitions expert Dave Watts e-mails.
3. This image.
4. A possible image I am seeking from Harry Woodman's archive.
One or both of these may have been the late Spandau Maxims that were the 13mm bore. So instead of the Air Master Parabellums I intend on using the Air Master Spandaus. Also over all they fit better than the Parabellums. Next to work out the triggering mechanism.
_VISITCOMMUNITY
Posted: Thursday, May 19, 2011 - 03:11 AM UTC
3. This image.
Recent research has proved to me at least that the 13mm Maxims were not used on this machine. So I'll be using the Air Master Spandaus.
_VISITCOMMUNITY
Posted: Thursday, May 19, 2011 - 03:36 AM UTC
Looking forward at the various angles that need to be negotiated for the Spandau Maxim gun support framing.
Working on the bits and bobs. Anything metal gets a coat of Testors Aluminum (buffable) and a coat of clear Dullcote. Next the Basic colour. The engine access cowls are being simulated to have heat distortion in the basic colour.
OEFFAG_153
_VISITCOMMUNITY
Posted: Thursday, May 19, 2011 - 07:49 PM UTC
HI Stephen – great to see you're making progress with this build – and looking great too! Hope to see more as it develops.
Best Regards
_VISITCOMMUNITY
Posted: Wednesday, June 08, 2011 - 03:54 AM UTC
Working on a few kit interior pieces.
Fuselage only held together not fixed yet.
_VISITCOMMUNITY
Posted: Saturday, June 18, 2011 - 03:14 AM UTC
Still don't like the idea of sitting on top on the gas tank, but excellent progress Stephen !
_VISITCOMMUNITY
Posted: Tuesday, July 19, 2011 - 09:35 PM UTC
Greetings all,
The build does progress. Images to post in the next couple of days. I am almost ready to close up the fuselage now. The cradle has come together well enough but I had to modifiy my early assumption that downward firing Parbellums were used when in fact it was Spandau Maxims. So I have switched from Master Parbellums to their Maxims.
wing_nut
_VISITCOMMUNITY
New Jersey, United States
KitMaker: 1,212 posts
AeroScale: 468 posts
Posted: Wednesday, July 20, 2011 - 03:17 AM UTC
Missed this thread until now. Looks good.
gajouette
_VISITCOMMUNITY
Texas, United States
KitMaker: 365 posts
AeroScale: 356 posts
Posted: Thursday, July 21, 2011 - 01:56 AM UTC
Stephen,
The ol'girl sure is coming along nicely my friend. Very impressive Master -Model PE.
Highest Regards,
Gregory Jouette
_VISITCOMMUNITY
Posted: Sunday, August 28, 2011 - 09:53 PM UTC
Good news! The rear cockpit cradle for the downward firing Spandaus is almost finished. I'll have some images in the next couple of days. I am trying to finish up some of these cockpit details. Then on to the engine.
wing_nut
_VISITCOMMUNITY
Posted: Monday, August 29, 2011 - 02:04 PM UTC
A couple of days? Unacceptable OK... sorry... we'll wait
_VISITCOMMUNITY
Posted: Tuesday, August 30, 2011 - 05:50 AM UTC
Well then I guess I should start. First to custom fit a scratchbuilt gun gradle I have to have some info. First the area inquestion needs to be plotted.
Here from the Flight Magazine of 1919 is the Close Air Support Gun Cradle from a late mode AEG J.I and is similar to the one seen in this thread's WnW images of Junkers J.I 816/17
