Hi,
...and the Yakzilla strikes again! After it was gathering dust somewhere on the shelf, I managed to get myself together and continue after several months brake. It is very hard to predict where this project is going to lead us, and I can only assure you that there is a plenty of work to be done. When you work on such a big project, you always find so many nooks and crannies that need further attention.
![](https://gallery.kitmaker.net/data/26892/Return-001.jpg)
![](https://gallery.kitmaker.net/data/26892/Return-002.jpg)
![](https://gallery.kitmaker.net/data/26892/Return-003.jpg)
It may appear a bit rough in outline at the moment, but it will be gradually refined and reworked until completion. The geometry of the kit was seriously compromised; therefore, I had to rework the stabilizer and the entire engine bearer in the front, because the engine was visibly offset. It does look better now, but it is far from being perfect.
The major step forward was the attachment of the upper fuselage and marrying with the tubular framework. This operation would have been complicated even without the framework, because the original fit of the kits part is at least suspect in that area. Nevertheless, I didn't start this project to mock the original kit but to enjoy the build and improve some of my skills... and the enjoyment it is!
Thanks to everyone who missed the thread! I don't promise to be that regular, but check it out from time to time - you might be surprised with a sudden breakthrough
All the best,
Entoni
