Thanks for the kind words everyone! Perhaps the admins will make an exception and let the F4B-4 into the KotS2 campaign without a figure, lol.
The rivets seem to have worked out well, and I'll definately use them again. I understand HGW also makes some of these, so I may have to try them out as well as I beleive they are less expensive than the Archer ones.
Ok, small update now that I've made the decision to model the modified aerial attachment bracket on the vertical stabilizor. I've got a really good hi-res photo of 6-F-1 with this modification, and can see that it consists of two flat pieces of metal attached to either side of the stab, and a metal rod that angles back to meet them. So, I used some .20 X .10 styrene strip, cut to 15mm to make the two flat parts, and some .20 styrene rod to make the rod part. I drilled a hole in the appropriate spot (the photo shows them attached above the anchors for the bracing wire) and started work. As the whole thing has a small post that sticks out above where all the parts come together, I bent the rod so that it would make up that part as well:
Parts attached, but not joined yet:
![](../../../img.photobucket.com/albums/v40/mgbdoug/Models/F4B/DSCN0706.jpg)
![](../../../img.photobucket.com/albums/v40/mgbdoug/Models/F4B/DSCN0709.jpg)
After they set, I joined them by tacking with superglue, then using ProWeld to help get a really good bond:
![](../../../img.photobucket.com/albums/v40/mgbdoug/Models/F4B/DSCN0714.jpg)
I then globed some more superglue on to the outside of the parts, as they need to all blend together at the top. Once it dries, I'll get it cleaned up and add a couple of attachment rivets on the strips per the real thing.
In related news, I also got the yellow paint (White Ensign USN Chrome Yellow) on the upper wing (and the wrap around on the underside of the leading edge). Now it's starting to look like something:
![](../../../img.photobucket.com/albums/v40/mgbdoug/Models/F4B/DSCN0712.jpg)
Here is a shot that shows the overall look with the modified aerial attachment (still need to take some off the top post part):
![](../../../img.photobucket.com/albums/v40/mgbdoug/Models/F4B/DSCN0715.jpg)
Still need to find some good photos of where the aerial wire attaches to the fuselage side (the one that comes down from the one that goes from the vertical stab to the right wingtip)
Thanks for looking! Comments/questions welcome!
Doug
