I will keep you updated when I start spraying my roundels! So the mailman will be the bottleneck for progress ![](../modules/SquawkBox/images/smilies/happy.gif)
Well, being a bottleneck was a bit understatement as until today the masks never arrived (I must admit that I never bothered myself to ask the company whether they have sent the masks anyway). As my GPU was almost finished and to keep some pace in this build, I decided to go for the decals.
The decals were horrible....
Their thickness is amazing, thick like pancakes. A lot of silvering with almost all decals, despite a nice gloss cote. Set and Sol hardly were able to improve anything.
The first decals to be applied were the big roundles on top of the vortex generators. A lot of Sol was applied to cover a the little bumps in a decent way. This was as best I could get them on:
![](../../i1091.photobucket.com/albums/i387/jelgervandermeer/P1060646_zpse39cd57a.jpg)
![](../../i1091.photobucket.com/albums/i387/jelgervandermeer/P1060645_zps5f724f76.jpg)
![](../../i1091.photobucket.com/albums/i387/jelgervandermeer/P1060644_zps579a6a61.jpg)
On this picture, the small antennas still have to be put back again.
From experience I knew that covering decals with a cote of varnish (in this case satin varnish) silvering will be a bit reduced and luckily this happened.
I spray varnish from the can and unfortunately, I was a bit enthusiastic and sprayed too fast too much varnish on the model. As a result, a bit of varnish build up on the rear parts of the wing, resulting in some ugly spots. Maybe with a bit of ultrafine sanding and adding a new cote of varnish, I can reduce these spots. Suggestions are very welcome for this. (This build takes too long, I get impatient and errors build up.....)
With the main steps of the build process being done, it is time for the finishing touches. After decalling (except for this one), this is one of the nicest things to do. It really makes the model alive. First thing to do were the radio panels on the bottom part of the wing.
A bit of masking:
![](../../i1091.photobucket.com/albums/i387/jelgervandermeer/P1060642_zpsbb839989.jpg)
Then brush painting:
![](../../i1091.photobucket.com/albums/i387/jelgervandermeer/P1060643_zps09454236.jpg)
To be continued!
Jelger
