Lance, Bernd - Thank you very much!
Jack, sure thing!
BrenGun.cz's photo-etch - I really liked it! The ordering process was smooth and I had it fast and no hassle. No Spandau jackets and no seatbelts included in the specific plane PE is a bit of a head scratcher, but value is still very good for what you get.
PROS: -It really adds to the kit! Corrected "chin pan" with open louvers and extending correctly over the fuselage, additions to interior framing and controls (visible through cockpit opening), separate access hatches over wood and metal fuselage and landing skid hardware - all provide that extra touch. There is respectable number of improvements to the original plastic, even if one is shy of real fine and tiny details.
-Brass is "just right". It can be bent and rolled without annealing, though the latter helps. Details range from big hatches to tiny wingnuts and full set of "loop and length" for making turnbuckles.
-Early and late details are clearly marked in the instructions.
CONS:-instructions are not really sufficient for the task of applying some of the detail pieces. Make sure to have Windsock Datafile 029 or other reference material on the subject. Some elements are straightforward and easy to place, some are drawn awkwardly, some are not clear and one detail illustrated completely wrong. The latter is the reason why my aim guide frames are too high - I corrected early on, but instructions place it with lines too far apart and aiming point way over pilot's point of view.
-instructions also don't clue you in when modifications are needed on Roden's plastic for parts to be installed. I was hoping for Eduard level of PE instructions, though most are rather obvious / can be guessed correctly.
Somewhere in between:-this is a precision Photo-etch kit for a very loosely fitting styrene kit... I had a couple of fitting difficulties, but I cannot tell if it was poorly fitted styrene or if brass was slightly undersized... My initial reaction would be to make "chin pan" slightly larger as it's pretty easy to mess that one up.
In retrospect, the CONS are really more of an "Experienced Builder only" - I'd probably have a lot less issues second build around or if I were more experience with building Roden kits.
In Conclusion, the kit is a welcome addition to the 1/32 Roden Siemens-Schuckert D.III (Late or early modification) - I certainly glad I have included the details in this build as they both noticeably enhance and add to the model... Makes the build more enjoyable process too.
Trying out a different backdrop (whitebalance is a tricky mistress):
![](../../i.imgur.com/uY4jEMS.jpg)
![](../../i.imgur.com/A2Z8yB3.jpg)
![](../../i.imgur.com/9N6Sa02.jpg)
P.S. I noticed that SSD.III feels to me like a German-built Camel...
