Thank you !
The rudder is controlled by two cables (one on each side of the plane) that line the lower beams ...
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0971_zpsbksenjeo.jpg)
... each cable passes through a pulley attached to the foot of the mat ...
Pulley on the inside of the mat:
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_6758_zpszyzibkpo.jpg)
Or pulley to the "outside" of the mat, you have the choice:
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0908_zpsfr7um6lo.jpg)
... then enters the cockpit somewhere there. I did not find precisely where.
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_091311_zpsu06ngej1.jpg)
As for how they are attached to the rudder I have no info.
The ailerons are connected to each other by a rigid bar and controlled by cables which come out of the wings by a pulley. One at the top, one at the bottom.
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0899_zps6jphpgn0.jpg)
The exact position of the cables ... between the mats, on the same side, on both sides etc etc I did at best.
![](../../i358.photobucket.com/albums/oo21/louisetcie/395198062384259_____voisinpeugeotg_zpsiysaqzzy.jpg)
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_6774_zpspmgesjfw.jpg)
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0929_zpsa8yjkbri.jpg)
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0968_zpscqbo1yyy.jpg)
The Pitot tube (well, I think that's it).
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0981_zpseygote3j.jpg)
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0991_zpshiennnix.jpg)
The plane is fixed to its base, there are so many cables that moving the plane is difficult. The wings are so long that they deform when I lift it. This eventually breaks the cables.
So I put two fishing lines through the base and I put them through each wheel, passing between two rays, knots and some glue.
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0994_zpso5qkejlp.jpg)
![](../../i358.photobucket.com/albums/oo21/louisetcie/IMG_0996_zpszyhcekoh.jpg)
A +
