1⁄35
Ta183 Bat Plane!a build story by Valentin Bueno
The AM Tech Kit |
The AM Tech kit in 1/48 scale is a little out of my
league. I usually build 1/72 scale, but the thought of flawless fitting Luft
46 kit was too good to pass up. I ordered the kit from Squadron and within a
week of its release date, it was on my workbench. The parts were a molded in
a very dark grey coloured plastic. The parts had a very nice smooth finish
and were free from flash. This wasn’t the usual limited run kit of a limited
interest item. Cool.
I started by putting the cockpit together. It was painted the expected RLM
66 Black Grey colour and highlighted with silver pencil and washes of black
paint. The seat had the cushions painted red, just to add a little colour to
such a drab cockpit. I added a drop of Microscale Gloss Clear to the
instrument faces to simulate glass-covered instruments. The main wheel well
bays were added next along with the tailpipe blanking plates. While these
set up, the holes for the wing pylons were opened up in the wings. The wing
halves were glued together and set aside to set. I inserted the cockpit
through the nose opening, glued it in place and added the intake. I sanded
all the seams and did a little too much sanding on the nose in front of the
canopy. This created a step between the fuselage and the windscreen that
would have to be filled in later. Drats!
With all the seams sanded, I attached the wings and tailplanes. Now it
started to look like a Bat Plane. I test fitted the bomb bay door and
promptly got it stuck in place. The fuselage was sealed and I hadn’t
installed any nose weight! Drats, drats and triple drats! Oh well. I added
the landing gear and tested the balance of the model. It was just on the
edge of tail sitting. I figured when I add the drop tanks and missiles,
it’ll tip forward. Time for paint! Copyright ©2002 - Text and
Photos by Val Bueno. All Rights Reserved. |
Project Photos
Copyright ©2021 by Valentin Bueno. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved.
