1⁄35Building A Better Rocket Pod
1
Comment
To make the job easier, I drilled out holes with a pin vise on the rocket pod's front.
Once this is done, just simply insert the rivets into the drilled holes and add a few drops of liquid glue where it's loose. Then you have yourself a rocket pod with warheads extending out as depicted below.
A simple thing to do for most modelers, but the end result definitely beats molded flat rocket pods.
:-) Nice tip Dave Unfortunately Spitfires don't carry them, but I will bare it in mind if I ever build anything with rocket pods :-)
Mal
JUN 15, 2003 - 06:07 AM
Copyright ©2021 by Dave. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2003-06-14 00:00:00. Unique Reads: 8396
