1⁄35A Nose Full of Teeth: The Bf110 Haifisch Zerstorer
Starting Off With the Cockpit
[click for larger images] |
At the beginning, let me
mention here that I have not used any of the commercial model paints like MM/Tamiya/Humbrol/etc,
for the simple reason that I don’t get these in India. Instead, I use an
acrylic paint called Fevicryl, which is a combination of white glue and acrylic
colour, and lends itself very well to airbrushing. I use references from the
IPMS Stockholm site, and brew up the colors approximately equal to the color
chips from primary colors. I first spray all the parts on the sprues with grey
automobile paint from a can, which helps the camo stay on better.
As usual, I started off with the cockpit. I generally find this to be the most intense of all my activities, and this time it was no different. I first painted the cockpit tub, instrument panel, seats and interiors of the fuselage in RLM02 Grau. Seat belt painting in a brown drab followed this, and then I sprayed the whole set with Future, followed by a black wash to bring out the depths.
Finally, the instruments on the panel were picked off with a toothpick. This is a very painful, finger numbing process and took me about 2 hours to complete to my satisfaction. After this was done, I inserted this into the cockpit tub, and attached it securely to the interior of the fuselage.
Making the Wheel Assemblies
The wheel assembly process was started off in parallel with the cockpit tub painting. First I masked off the wheel hubs using Scotch tape, and gave it a spray of Matt Black from a can. Then I reversed the masking, and painted the wheel hubs in RLM02 Grau. The wheel carriages were assembled, painted and attached to the wheels when dry and kept aside. The interiors of the wheel bay doors were also painted in Grau, as was the well base before attaching to the underwing piece. |
[click for larger image] |
