1⁄35The Future Is Klear
5
Hand brushing Klear
The trick to hand brushing Klear is to brush it on thinly; you could just apply one thick coat and leave it at that. The problem with that is that you will fill in all the engraved detail and will probably get runs. Apart from using Klear as a gloss coat on which to apply decals it also acts as a barrier to petroleum based washes, i.e. white spirit, turpentine, or any other thinners used for enamel paints. I haven't use lighter fuel or cellulose thinner in a wash over Klear, so be cautious of those. I apply it over the decals as well, to protect them from the wash and to level the surface around the decals.
You will require: 1. A soft bristled, flat 1/2" brush 2. Johnson's Klear 3. A film canister 4. A disposable container for water 5. Tack rag |
Nice one Mal
That's an excellent How-To Feature :-)
Really nicely written and laid out to explain the techniques clearly. :-)
SEP 07, 2003 - 06:22 PM
Hi Mal,
Well done.
I have used Future/Klear for a few years now. Airbrushing can be tricky. Frequently I get 'orange peel', the patchy surface you may be writing of. I have found that multiple VERY LIGHT coats attenuate this.
TO REMOVE this product, use ammonia, which almost instantaneously disolves it. I have removed Future with ammonia from Pactra Acryic, Polly Scale and AeroMaster without any effect on the unsealed paint.
And you gotta luv that smell!
All the best,
Fred
SEP 20, 2003 - 06:04 AM
Thanks HoldFast -
I was going to AB Future onto my models before i did thier wash to help the wash run into the recesses.
I'll brush it by hand now, b/c I sure dont want pooling and I really dont want to lose any surface detail either.
Thanks for the fine feature.
NOV 07, 2003 - 12:13 PM
Copyright ©2021 by Mal Mayfield. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2003-09-08 00:00:00. Unique Reads: 23868
