1⁄35Scribing Made Eezee?
5
However because of the way I finish and particularly, weather my models, I much prefer the scribed panel detailing. A lot of the models that I would consider scribing are the only ones available in 1/48 scale, so the choice is either live with the raised detail or scribe. I choose to scribe but I still find it a chore, or did until part way through scribing the Revell re-issue of the excellent Monogram B-26B/G Marauder, for this article, more later.
Tools
There are many scribing tools on the market, but for the method I will describe the Olfa-P cutter seems to be the best. You will also require a tool with a simple point, this could simply be a sharpened needle, I have a “pointy” scriber, which I think is a Verlinden tool? I have quite a few others, most of which are home made but since discovering my EEZEE scribing method, I think they are all but redundant.These tools can be seen in the second picture, the Olfa-P cutter has the yellow handle and the pointy tool has the rubber finger grip. There is a very useful, homemade tool which isn’t redundant and is used for scribing rivets and dezus fasteners. I will describe how to make it at the end of the article. Other tools that are necessary are straight edges and scribing templates. My EEZEE method has made most of my straight edges redundant as well. You will see the scribing templates used, mine are by Verlinden. There are plenty of others on the market.
Nice article, Mal....
and now I know what to do with the small collection of glue needle applicators, collected over the years.
JAN 06, 2005 - 03:39 PM
Great stuff Mal.
I am currently in the process of rescribing a 1/72 hasegawa hellcat. I work on it a little, put it away for a month, pull it out again, etc. Maybe this easier method will help me finish it before my death .
Thanks for doing the leg work on this one.
Leon
JAN 07, 2005 - 02:40 AM
Yes dave everything has it's uses, eventually. Leon, I have a Monogram F105, which I have had for many years. It was the first thing I tried scribing and managed about 3 lines. It has many more than the A-26 but I feel confident, at last, that I might actually get it finished.
Mal
JAN 08, 2005 - 03:27 AM
Hi Mal
There are a couple of other types of tape which I use for scribing. Both are plastic, so they may be a bit more robust than Tamiya masking tape.
The first is by Pactra and is available in model shops - this stuff is really flexible as you can see:
The second is a different type of Dymo tape. It's used to print (rather than punch) labels and is thinner and so more flexible than the normal stuff - but not as flexible as the Pactra tape:
I've also used litho-tape, available from art shops. Again it's plastic, but it's nice and flexible.
Thanks for an excellent article and I hope these suggestions are helpful.
JAN 09, 2005 - 05:15 AM
Wow great stuff Rowan, a tape that is thicker than Tamiya tape and is plastic, but is as flexible would be even better.
Mal
JAN 09, 2005 - 06:12 AM
Copyright ©2021 by Mal Mayfield. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved. Originally published on: 2005-01-06 00:00:00. Unique Reads: 26480
