1⁄35F14A Tomcat - PART THREE
With the intakes completed and fully attached, I attached the forward
fuselage to the rear fuselage. The joint between the forward and rear fuselage
did not align well. The cross-section shapes of the two fuselage sections are
not the same. I used a heavy styrene strip to widen the upper portion of the
rear fuselage opening. This helped the forward and rear fuselage shapes to match
each other better.
By this time, I was getting used to applying liberal amounts of filler to this
kit. I applied some more filler and sanded it out to smooth the fuselage joint.
I also needed to reinforce the inner structure of the fuselage joint. I had
placed a lot of lead shot in the nose area of the model to guarantee the it
would sit correctly on its landing gear. This made me fear that the nose section
would get broken off if I was not careful. The reinforcing gave me some peace of
mind.
At this point I was holding a nearly completed fuselage that was starting to
really look like a Tomcat. I thought the big issues were finally past, but I had
one more to go -- the wings. The wing problems relate mostly to the wing flaps
and the pieces that go into the wing flap construction to support the lowered
wing flaps.
To build the model with the flaps retracted (up), things fit pretty much as
advertised. All that is needed is to thin the trailing edge of the upper wing
piece, and the flap slides in with very little extra effort. Not readily
apparent in the instructions is that the "eyelid" doors (kit parts C1 and C8)
are discarded when the flaps are up.
