1⁄35F14A Tomcat - PART THREE
Building the model with the flaps positioned down is where the fun starts. I
found the flap pieces do not fit the wings as well as they could. Troubles start
with the "eyelid" doors. First off, the instruction sheet has these parts
labeled backwards. Put C1 where the instructions tell you to put C8, and vice
versa. Even when these pieces are on the correct side, they are still too thick
to fit into the thin space between the upper and lower wing pieces. I ended up
separating these doors into three pieces each, cutting and filing away some of
their backing portions, to get them to go into place.
Copyright ©2021 by David W. Aungst. Images also by copyright holder unless otherwise noted. The views and opinions expressed herein are solely the views and opinions of the authors and/or contributors to this Web site and do not necessarily represent the views and/or opinions of AeroScale, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of AeroScale. All rights reserved.
