Here are the first pictures of my new diorama project. It will be a maintenance scene in the Aleutian in 1942/43. The photo that inspired me is this one:
The area is quite busy! More than ten planes in various states are parked in a PSP cell with lots of equipment and vehicles. Of course I won't be able to reproduce all that is visible in the original scene but I will try to make the most possible...
For the base, I used a 120X90 cm piece of wood board. The PSP plates from Mark58 were then screwed in place rather than glued to obtain a more solid fixing...
To level the surface, I used 5mm thick PVC plates cut to shape. These were also screwed to the wood board. I placed some models to get a basic idea of the diorama...
All the joints between the PVC plates were filled with Polyfilla (filler used to smooth the surface of walls). The blue surrounding is meant to represent the artificial hills which resulted from the construction of the airfield. They were made out of Styrofoam
To cut the foam I used a "Hot Knife" from "Hot Wire Foam Factory" (see website here). While not much faster than an usual knife, the "Hot knife" allow to obtain a more realistic surface...
In this picture you can see all the references I gathered for this project so far:
- a P-38 from Hasegawa
- a P-40K from Hasegawa (with BigEd from Eduard)
- two P-39 from Eduard (with Verlinden, CMK and Cutting Edge detail sets)
- two Allison engines (from CMK and Aires)
- a Cargo Truck from Tamiya (just released
- a tractor from the Revell/Monogram WW2 airfield accessories kit
- a cletrac from the Monogram B-24 kit
- Eduard, Preiser, Verlinden, Tarmac, Monogram etc... figures
- various equipment from Signifer
- two tents from Custom Dioramics
- a Nissen hut from Flightpath
- etc...
This is the current status of the diorama. I have added a coat of resin to blend and secure everything together. I also filled the holes from the screws. Next step will be to add a coat of sand to have a nice texture for painting...
This will be a long term project so don't expect daily updates from me...
