Time to update you on what’s been going on with the Jug
The fuselage halves are glued together and there was a god fit after that I´ve sanded of some material from the interior diameter. I did paint some oilpaint the interior tubs and duct at an early stage. After pressing the halves together the paint told me ware to sand of. No Hi-tech, but it did the job.
I will only do the job in one of the gunbays so I´ve started detailing up that one. There is some more paint add wires do add.
The wings is now in place so it’s starting to look like an aircraft so the rest of this evening I will do some filling and sanding on the gaps between the wing and fuselage. I’ll going to use Milliput for this job. Milliput will give me to sculpt the filling so there will be as little sanding as possible
For this time
Larsa
