If you have been following my Roden BE2c build over on the other forum, you will know that I have made ny first "Serious" attempt at hand carving a four blader.
Here is the process in photgraphic form.
Cont'd...
Rob Gardner wrote "From the records that I have so far, the following makers made props for various Albatros aircraft;
Astra
Axial
Eta
Behrend & Rüggebrecht
Garuda
Heine
Imperial
Reschke
Wolff
Wotan
Of these makers, five made props for the Albatros D V
Axial
Garuda
Heine
Wolff
Wotan
Others may have as well because I have details of a further eight Albatri props where I could not identify the maker.
The Axial Albatros DV prop was the Type 87. This was probably used on an earlier type of aircraft first as the Albatros D III used the Type 95 which was also used on the Fokker D VII and D VIII. The Fokker D VII also used an Axial Type 18 62 prop.
You can see that I have not yet unravelled Axial's type numbering. I have details of thirteen so far. If any other forumite can give me details of any other Axial type and its use I would be extremely grateful."
