Thank you for the kind remarks. Everyones comments have kept me motivated to finish this one.
Here is as far as I got this weekend. I mentioned before that the oil tank cowling was missing from my kit. I cut the out the replacement from the Hobby Craft parts. I used plastic strip to make the dimensions fit the Aries pieces. A lot of sanding and grinding was required
Couple of lessons learned if you tackle this Aries detail kit.
1. It is missing a lot of detail at the rear of the engine. The hydraulic pump, the water pump, and the electrical bus on the right of the engine are all missing. I chose to only partially tackle these issues.
2. Save placing the photo etch heat deflectors and exhaust till the end. They do not fit and you will have to trim them. It is easier to add the wiring with these items off.
3. Do not place the prop hub on until the end. It WILL break off.
4. The super charger intake is incorrect and does not line up with the engine bearer. I used plastic tube and some photo etch screen to improve it.
5. Oil paint (Model Master) seems to work better on the wiring pieces. It takes longer to dry, but is more flexible and resists chipping.
