Sorry folks for the delay in updating this thread. Life always seems to get in the way of my hobbies. The build has been a long affair, with a lot of measure twice, cut once, and curse because I should have measured three times.
Vance asked about some of the fine points on the build. First of all, I love the base hobbycraft kit. I have built several of these (I know the Has kit is much more detailed). You can't beat the price and they go together well. A great platform for practicing painting Luftwaffe schemes for that Has masterpiece waiting in the closet. As for the 199, if you did nothing to the kit, it would look like a 199.
The Aires detail set so far has worked well. The only issue to this point in the build has been getting the instrument panel to fit. I used a contour gauge on the opening and cut out a backing plate out of sheet. This also gave a much more secure join of the panel to the cockpit opening. The rest of the Aries cockpit fit like a glove.
If you are going to be really accurate the bottom needs to have the MG131 ejection chutes covered over. On the 199 the spent shells were captured in a compartment of the magazine. I also added 4 prominent scoops made from plastic rod and sanded to shape.
The Israeli machines were early 199s so they had the battery hatch cover (I think that’s what it is) behind the pilot’s seat. I made this from scrap plastic and corrected my earlier omission. Here are the rest of the progress shots. (At least I hope these are) I did add the ETC rack from VP since my source showed that it was left on most of the aircraft even if they were not carrying bombs.
More to follow.
